Subaru Tech All We'll Drive
Gaskets today!
Old Jan 30, 2007 | 08:08 AM
ryan_west06's Avatar
Talking Gaskets today!
Getting my DP gaskets today and will be putting it on. I ordered 2 just to have a extra one or if someone needs one right away! (just email me if ya do)
Im about 99% sure its the DP Gasket thats causeing the noise and slight pop at low rpms. If it was the up pipe i dont think id be hitting 17 psi every time i run it hard. Well we will see today! ill let you all know.
Old Jan 30, 2007 | 08:25 AM
djerickd's Avatar
CHILLING SPREE!!!
Mine pops(afterfire) sometimes when I rev it at idle if that helps, I think it's normal but I would have to hear yours to be sure...
SnowMan Tuned
Old Jan 30, 2007 | 08:28 AM
but im thinking its leaking because when i put my hand under the upipe i feel water and a little air when i rev it up! why would there be water there?
Old Jan 30, 2007 | 08:53 AM
JonLGT's Avatar
Just for decoration
You sure its water? Like coolant water?
Old Jan 30, 2007 | 08:59 AM
sorry! on my last post i ment to say when i put my hand under the DP i feel water and some air comeing out when i rev it up! did i mention i can smell the fumes too! The water doesnt really smell like much! but its clear.
Old Jan 30, 2007 | 09:04 AM
JonLGT's Avatar
Just for decoration
There is a rubber AC drain line that runs right above the downpipe, check that first.
Old Jan 30, 2007 | 09:11 AM
im postive its not that! it leaking air and i wanna say condensation right where the gasket is. and i cant see if there is soot because its on the bottom. but its makeing the shity noise when i rev and it pops at low rpm
Old Jan 30, 2007 | 09:34 AM
JonLGT's Avatar
Just for decoration
I would be more worried about the water, but a new gasket could do the trick. Make sure all the bolts are torqued down pretty good also.
Old Jan 30, 2007 | 01:37 PM
fat angel's Avatar
Secret Squirrel
this should have been put into your other thread.
Old Jan 30, 2007 | 02:42 PM
My bad about making a new thread. So heres the deal. Raised the car and looked at everything. Come to find out... the header/up pipe gasket is blown. One bolt missing and a ton of soot around each bolt. Ill have it fixed tomorrow. Damnit, i ordered those DP gaskets for no reason. Oh well, i need to replace the used one anyways. ive been running my car like this for a month!!!!! SUCKS...
