Stock Dyno pull...
Your max boost is 1.2bar, or is that just how high your gauge goes up to... Sorry, your post was a little cryptic. 1 bar = ~14.5 psi. If you're pushing 1.2bar (17.4 psi) through a stock turbo and stock fuel system, there are issues.
Thays at MAX Boost for like a second, mainly seen 1.0 but it drops fast at high RPM. Maybe need a boost controller to keep it from dying off at the end. I got an Autometer Cobalt Boost gauge I will be installing to get these numbers right once and for all, Also will be installing the Uppipe and TBE next weekend and then get another pull on the dyno to get new numbers.
All I was saying in my post is that dynos are different and that the dyno at S&R is most likely more realistic and than alot of the other brands out there... nothing I said was intended to be negative...... And I also completely agree, as long as I see a substantial difference between one part and the other I don't care what the number really is... as long as its higher
