Subaru Tech All We'll Drive
egt gauge
Old Jan 12, 2007 | 07:33 AM
albie1kanobi's Avatar
The one and only.
Originally Posted by RonnieMack
What are you wronging? ME?? I don't think so!
nah, i was referring to fastraft wrx.
me=ninja skills!!!
damn those ninja skills!
"Is it blaspheme to swap a 4G63 into a Subaru? "
Old Jan 12, 2007 | 07:38 AM
JonLGT's Avatar
Just for decoration
Take the manifold off before you drill!!!! If you plan on doing it yourself that is.
FastRaft WRX's Avatar
Down South Supplier
i fail, mine was in my downpipe ha
Originally Posted by blacksti
stop trying to be cool telling people you kicked me out of your tree house lmao dude fs is gay get over it
Originally Posted by antibling
bob you are just way too cool
Old Jan 12, 2007 | 07:39 AM
schoellnasty's Avatar
Ive also heard of many people tapping on the casting button on the drivers side manifold.
Old Jan 12, 2007 | 07:41 AM
RonnieMack's Avatar
That casting button is precisely where to drill/tap. It's right under #4...
Old Jan 12, 2007 | 07:43 AM
RonnieMack's Avatar
Just check out scoobymods dot com. There is a very good write up on how to do it. There are MANY good write ups on that site. Check it out.
Old Jan 12, 2007 | 07:46 AM
  #17 (permalink)
JonLGT's Avatar
Just for decoration
Not really fail, just will have less accurate readings.
Old Jan 12, 2007 | 08:55 AM
  #18 (permalink)
Alizarin's Avatar
Gravel fiend
Correction... it will have lower readings. They won't be less accurate, just lower temperature readings.
I had my drill/tap done at the same time as a ceramic coat on the manifolds. I used the casting button on the driver's side as the approximate location.
Old Jan 12, 2007 | 09:04 AM
  #19 (permalink)
813_05_STi's Avatar
Am I OG Yet ?
No.. Not the downpipe. Or the up-pipe. You should drill/tap for egt on the header under #4 cylinder. That's the one that burns the hottest and that's the one that will give you the most accurate readings.
Wrong, #3 Burns the Hottest but you were close
Old Jan 12, 2007 | 10:38 AM
  #20 (permalink)
stiscooby's Avatar
mech engineer
yea, ive always heard 3. i think SS said 3 to me before. he made fun of me when i said it was in the dp.
-Matt
