Coolant Leak?
Down South Supplier
on
Coolant Leak?
So i filled up coolant last night, i check today after a short drive to school and back and my resevoir is empty! I check the radiator it self and that was full, i also checked the turbo coolant resevoir and that was full....
There was a bit of coolant under the radiator and a little bit on the fans, yet I cant find any visable cracks/leaks on the radiator, any suggestions?
Down South Supplier
on
both
i filled up the resevoir last night and its already down past LOW after a 20 min drive today
You probably aren't leaking anything. When I had a coolant leak, it was very noticeable by checking the coolant tank for the turbo......it was always low. I could also smell coolant just by walking near my car.
550/550
