Subaru Tech All We'll Drive
What can you use to clean a turbo?
Old Nov 25, 2006 | 08:42 AM
blacksleeper's Avatar
Giggity Giggity Gone
Question What can you use to clean a turbo?
What type of cleaner can you use to clean the exhaust housing of the turbo to remove the excess oil build up?
Old Nov 25, 2006 | 04:49 PM
is there no way to remove this? or is it not even worth the effort?
Old Nov 25, 2006 | 04:56 PM
Dan W.'s Avatar
__________
Idk if this would work but how about brake cleaner or Blaster? Just an idea i had.
Old Nov 25, 2006 | 06:32 PM
yeah i found another forum that said to use brake cleaner or something like it.
Old Nov 25, 2006 | 07:31 PM
marksaccord95's Avatar
TR Registered Member #5
brake parts cleaner, rinse it down when your done, most are chlorine baised.
http://www.floridaracing.org
Old Nov 25, 2006 | 07:57 PM
YARO's Avatar
Smith & Wesson Protected.
Yeah i clean mine before with brake parts cleaner than degreaserand water...came out clean as new
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Nov 26, 2006 | 07:08 AM
Alizarin's Avatar
Gravel fiend
I would throw in a caution to be careful not to damage the turbine wheel if you're cleaning some of the inside parts of the housing. That's about all I've got.
Old Nov 26, 2006 | 09:30 AM
caelismadison's Avatar
Get some diesel fuel and a brush. It will work alot better than brake cleaner. Or get some ATF, works very good as well.
Old Nov 26, 2006 | 09:37 AM
i'm only going to clean the external parts and the exhaust housing where it attaches to the downpipe. i'm not planning on cleaning the internal parts.
Old Nov 26, 2006 | 07:34 PM
no use in cleaning the exhaust housing unless your going to coat it, its just going to look like ass again soon.
