Subaru Tech All We'll Drive
check engine light an blinking cruise
Old Nov 25, 2006 | 03:55 AM
I'm Slow's Avatar
I'm Slow
^ cobb does fix the P0420 from popping due to the catless exhaust. If you keep getting that cel then you have a leak somewhere else. Check your coolant lines,fuel pump and gasket,gas cap, and all vacuum hoses.
Old Nov 25, 2006 | 03:56 AM
I'm Slow's Avatar
I'm Slow
Originally Posted by WTFchuck
whats this mean... jsut out of no where came on this morning... i've had my dp on since last sat... an this is the first time its happend
Do you have a mechanical or electrical fix on the o2 sensor? the cruise light blinks whenever the CEL light comes on.
Old Nov 25, 2006 | 08:32 AM
BigBadChad's Avatar
The Beauty of AWD
i put my dp on a few months ago, gave me the same prob but i got a CEL Boss thats sposed to fix it but im told i have to re-flash my ecu for it to actually work- ne advice?
Old Nov 25, 2006 | 01:20 PM
3gsucks's Avatar
yeah with a cel fix i got low voltage on O2 bank 2. that CEL is probably nothing.
I dont know what your setup is but with my txs stealth back with cat and the factory axle back i did not creep.
definately get a tune. it makes the car .
check out Enginuity.org and Osecuroms.org its a great way to get a tune for cheap
or Snowman
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Old Nov 25, 2006 | 01:50 PM
aznkrunk's Avatar
10 graphix= 500hp
I need to check all my lines n stuff hmm.. I thought it was just a stupid code.. thanks for the info I'll check it right now my car did seem like it was having a burning smell even after i changed my oil and stuff
New setup in progress
Old Nov 25, 2006 | 08:45 PM
  #17 (permalink)
I'm Slow's Avatar
I'm Slow
the other thing is, if you fix the problem and drive around normally for 2-3 days the cel will actually turn off on it's own once the ECU realizes eveyrything is working properly again. Suprised the hell out of the first time it happened, I always used to reset my ECU to clear the code but not anymore.
