thinking of going to an external gate
Guest
Posts: n/a
im currently running the FP Green turbo with an internal gate setup. what are the advantage over switching over to the external gate? what all needs to be achive this? i know i would need to weld the wastegate shut, i would need the tial wastegate, i would need a new upipe with the flange for the wastegate, i also would need some custom welding to my dp. anything im missing??
any help would be appreciated
Tuning... also it will be hard to fit an EWG-ed up pipe with that monster DP. I think the FP greens internal gate is sufficient enough to control the boost you want. Unless im wrong. The advantege of the EWG is absolute pinpoint boost control. I say unless you're having boost control issues you should spend the money elswhere.
Do you have the TXS downpipe? For the uppipe one could be fabbed to fit, to clear the 4" DP or you can weld your own. Or I'll sell you mine and you can get it modded. You don't need to weld the dump tube into the downpipe unless you think it's too loud, I'm not going to.
oh you need a re-tune of course...
SnowMan Tuned
SnowMan Tuned
you also don't need to weld the FP Green's IWG, you can remove it and fab up a bracket to hold it shut.
Area1320 Subaru & DSM Turbo Fabrication! Shipped Daily! may have some brackets made up for the green.
EDIT: If you do that you keep the FP Green's resale value
SnowMan Tuned
SnowMan Tuned
vids!
YouTube - Sounds of an STi w/ 44mm external wastegate dump
http://www.fototime.com/8CB6E9F479B9256/conv.wmv
Putfile - 4th gear pull
SnowMan Tuned
SnowMan Tuned
faded, i thought you wanted to go with a rotated setup? those kits are external setups and comes with what's necessary.
"Is it blaspheme to swap a 4G63 into a Subaru? "
