Subaru Tech All We'll Drive
Turbo Question.
Old Oct 24, 2006 | 12:17 PM
cpages2's Avatar
PWN5 J00
Default Turbo Question.
So my friend has a practly brand new VF39 Turbo he wants to sell me for $400.00
I was thinkign about buying it for my 04 WRX, But I have a few questions.
1) Is 400 a good price?
2) Right now all I have on my car is SPT Catback, SPT Intake and some suspension stuff. What else would I need to use this turbo?
Thanks,
Mike
Rally driving, when you're fertile enough to impregnate women with eye-contact
Old Oct 24, 2006 | 04:02 PM
aznkrunk's Avatar
10 graphix= 500hp
umm.....injectors top mount fuel pump etc just search on nasioc n also get a tune
New setup in progress
Old Oct 24, 2006 | 05:23 PM
djerickd's Avatar
CHILLING SPREE!!!
how many miles are on it?
SnowMan Tuned
Old Oct 26, 2006 | 04:34 AM
cpages2's Avatar
PWN5 J00
I think he said 5K Miles.
Should I even bother with a VF39? What kinda of power gain will I see with everythign listed above done?
Old Oct 26, 2006 | 05:27 AM
stiscooby's Avatar
mech engineer
well, i would ask him if he is gonna sell the injectors too. anyway, you will probably need to go with a bigger topmount, a new fuel pump(not very expensive) and either a boost controller or just the solenoid that Faded mentioned. then a kick ass tune. Your power gain should be very efficient. dont quote me, but ive heard some getting a good 300 or so with the set up.
vf39(hopefully with injectors): 400
Topmount: (used) 4-500
Fuel Pump(255lph): 83.99 shipped haha
Perrin boost solenoid: 80-100 (depending where you buy it)
Tune: (initial)850, (if tuned already) 150/hr
Total: depending on your route will be from 1000-2000. not bad.
-Matt
Old Oct 26, 2006 | 05:37 AM
djerickd's Avatar
CHILLING SPREE!!!
you can get a GMC typhoon/syclone boost solenoid and pigtail for $36...
SnowMan Tuned
Old Oct 26, 2006 | 07:39 AM
2TurboImports's Avatar
sooo...where's the turbo?
a rough guestimmation is for every 1 CFM = 1.34 hp. The vf-39 flows around 120 more CFM than the stock wrx turbo (with a PR of 2.0 (14.7 psi)). This can add up to ~160 hp, however this is best case paper scenario leaving out quite a few variables that would have impact.
Soo, having fun you could say that 'at the most absolute best, in a perfect environment (at the stock 14.7 PSI)' you would be in the range of 227+10 (lowball the gains from SPT) + 160 = 397 at the engine. Imagine a 25% drivetrain loss and that's in the area of 298-300whp. Put on some additional mods (up/dwn pipes) or possibly up the boost a few psi (then you can get into the larger TMIC needs) and that'd be the neighborhood of where your car would sit (in real life, not on paper since the additional mods would make up for most of what I left out).
That isn't really too far off from some of the numbers that some rex's w/ VF-39s and supporting mods have put out.
Old Oct 26, 2006 | 11:21 AM
stiscooby's Avatar
mech engineer
i would do it haha. that sounds like fun man. if he isnt throwin in injectors, say 350 for the turbo.
i sometimes wish i had a wrx to hook up. yea, im lucky to have the sti, but i wouldnt mind having an sweet and fast wrx. damn, good luck on w/e you decide to do
-Matt
Old Oct 26, 2006 | 12:09 PM
enash99's Avatar
92 DSM AWD
I have the vf-34 which is just a tiny bit larger than the 39,
here is my mod list
Mod list for my 2003 Platinum Silver Metalic Sedan
Engine Perfomance
ERZ Uppipe Thermotec wrapped.
Full Scooby Sport TBE Downpipe and Mid Pipe thermotec wrapped.
VF-34 Turbo with heat wrapping
STI Pink injectors 565cc
Samco Silcone Turbo Inlet pipe
Ver.7 JDM STI Spec - C TMIC
Ver.7 JDM STI Spec - C Shroud / Gasket
Ver.7 JDM STI Spec - C Spray Kit w/Button and Microswitch
Ver.7 JDM STI Spec - C STI y-pipe
Vishnu UD pulley
Apexi turbo timmer
K&N intake.
Brakes/Mounts
Group N Tranny mount
Goodridge SS Brake Lines
Frozen Rotor slotted and cryoed front rotors
Racingbrake rear slotted and drilled rotors
Porterfield RS-4 brake pads front / rear
Suspension:
Prodrive Springs
Koni adjustable Struts
Rota Wheels /W Kumho MX tires
Lighweight lug nuts,
Hotchkis Front Hollow Swaybar 25.1mm
Whiteline Rear Adjustable Sway Bar
Kartboy Rear Aluminum Drop Links
Noltec Front Drop Links
Engine Management
COBB Engine Management and Accessport Protuned By Scott Siegel.
