Need Opinion. Help.
I went to put on the turbo xs downpipe that i have had in my garage.
Once I pulled the old downpipe out and went to put the new one in I put the downpipe on but the cat back adapter would not connect
The holes on the flang would not line up with the cat back.
does anyone know of a cat back that will mate with that adapter or a place that will cut the flang off and reweld it so it will mate? or do you think I should buy an new adapter and midpipe that i know should connect up? or just get a totally different downpipe all together?
I finished the work late today so i was not able to get the old one on so right now im running open downpipe
. and i have school 45 mins. away tomorrow.
. The holes on the flang would not line up with the cat back.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
get the turbo xs midpipe, i remember you said you wanted the stock axel back
TurboXS 3" Mid Pipe - TurboXS Exhaust Pieces a la Carte
I may buy a mid pipe but then i would have to buy a test pipe too $$$. But im just questioning the fitment of turbo xs now. I may get on the phone with turbo xs to make sure that if i buy a test pipe and midpipe that it will definatly work with the axle back. Another problem is I could buy another downpipe for the price of the midpipe
This use to be 813_05_Sti downpipe, Bran what exhaust did you use with this downpipe?
did you have a cat-back or a full turbo xs system? I did not know you were running a txs downpipe.
This part allows the use of the TurboXS Super-Huge Downpipe with most any standard cat-back exhaust (but not the stock cat-back).
i think that stuff in the parenthese is where i screwed up at
. of all the reading and stuff i do i missed the most important part
yeah ill probably do that come friday i get paid. I guess im going to have to put the stock stuff back on till i can get the right stuff, but open downpipe sound sick.
i made a little diagram to illistrate what is wrong i think when i get around to it ill just have the adapter flang cut and rewelded.
but i still have the problem of getting cel even with a mechnical fix
I'm sorry this didnt work
This is the same problem James (Faded) had. I figured it might have been his exhuast since it was a turbo-back it may be designed different. PM Brian and see what he was running.
