Subaru Tech All We'll Drive
Heat wrap and sheilding testing...need some help
Old Sep 11, 2006 | 08:28 AM
tkrskyline's Avatar
TR Balla Donor Supreme
Default Heat wrap and sheilding testing...need some help
I would like top test the effectiveness of all my heat wrapping and need some help. I would like to compare engine bay temps and intercooler temps in a few different spots on my car VS a bone stock sti or one with just a APS TBE. So far I have wrapped the turbo and exhaust as best I can and place gold reflective sheilding on the inside of the heat shield, Y pipe, and intercooler end tanks.
What I need if anyone can help:
A temperature probe of some sort that I can tape in place and drive
A stock or close to stock 06 sti and a little spare time to drive around with me under equal conditions
Old Sep 11, 2006 | 10:18 AM
JonLGT's Avatar
Just for decoration
I dont mean to Hijack this but how many feet did you use to wrap your downpipe.
Old Sep 11, 2006 | 12:59 PM
tkrskyline's Avatar
Dont know...I used the whole 50 ft roll and got the turbo to the end of the resonator on the APS TBE.
BTW...anyone that uses this stuff, try not to touch your arms with it as they will itch and feel uncomfortable for hours. I think there is fibers in it similar to fiber glass.
Old Sep 11, 2006 | 01:51 PM
weverb's Avatar
You can get some cheap thermal couples (about 15' long) and tape/attach them any where. You can also get a cheap meter to plug them into. We have them at work. Unfortunately I work in Orlando.
Old Sep 11, 2006 | 02:29 PM
tkrskyline's Avatar
Where would I get these and how much. Not willing to spend a lot of money on this. I Would like to be able to read this while driving. if the meter has some wire, and can put the sensor in place and tape the display to the windsheild so i dont ahve to run wires
Old Sep 12, 2006 | 07:30 AM
weverb's Avatar
I will see if I can get some part numbers for you.
Old Sep 12, 2006 | 07:52 AM
djerickd's Avatar
CHILLING SPREE!!!
My fingers touching your heatshield isn't a good test
SnowMan Tuned
Old Sep 12, 2006 | 08:44 AM
weverb's Avatar
Here is what we have at work. You can just attach the thermocouple to where ever you want to take a reading and run the wire into the car. We use the Fluke meter here.
Thermocouples:
Thermocouple Wire - K Type, Duplex Insulated
Connectors:
Standard Size Connectors With and Without Write-on Window, and With Glass Filled Nylon or the Higher Temperature Liquid Crystal Polymer Shells
Thermometer:
eBay: FLUKE 52 K/J DIGITAL THERMOMETER W/THERMOCOUPLES/CASE (item 250026557890 end time Sep-13-06 19:15:06 PDT)
Datalogger Thermometer
Old Sep 12, 2006 | 12:16 PM
tkrskyline's Avatar
Thats getting into big money. Tried bidding on that one on ebay, but someone is willing to pay quite a bit. Need to find someone that can let me borrow a similar unit for the test
Old Sep 12, 2006 | 12:19 PM
tkrskyline's Avatar
I just realized the thermometer i have for my smoker may work. It reads temps in the range i am looking at and has a remote display that i can put in the car. I doest react very fast, but should do. It also has two probes
