Subaru Tech All We'll Drive
CEL Po442 help needed
Old Aug 22, 2006 | 05:07 AM
  #31 (permalink)
mantra1's Avatar
Shaggin' Wagon IV
I had this cel after my shortblock install. There is a small blue hose that came loose just below and left of the alternator. I can't remember if it's a vacuum or evap hose but it was off. This is always overlooked as a problem with the gas cap. I recommend a flash light as it can be a little tough to find. Call me if you can't find it. 813-505-8921
Rob
Old Aug 22, 2006 | 06:08 AM
  #32 (permalink)
I'm Slow's Avatar
I'm Slow
yeah, I read somewhere that it was the cause for someone else but mine is on and appears to be tight. What other lines are included in the evap system? I wonder if there is a diagram or outline of all of them
Old Aug 22, 2006 | 08:31 AM
  #33 (permalink)
StiGuy's Avatar
4 doors & 6 on the floor
Have you recently messed with your fuel pump? If so make sure the gasket where it seals to the tank is on correctly and the nuts torqued in proper sequence.
Old Aug 22, 2006 | 08:50 AM
  #34 (permalink)
I'm Slow's Avatar
I'm Slow
No, I did my fuel pump at 3k miles. 1 1/2 years ago. I now have about 18k miles on this setup.
Old Aug 22, 2006 | 01:14 PM
  #35 (permalink)
djerickd's Avatar
CHILLING SPREE!!!
Rob
I was thinking this too, I got a P0457 for the blue vacumm tee being disco'ed.. it's worth checking at least.
SnowMan Tuned
Old Aug 22, 2006 | 06:45 PM
  #36 (permalink)
Wrx_Chick's Avatar
~Local Hottie~
Exclamation
Check this one out, maybe who knows
ScoobyMods - P0447 evaporative emission control system vent control; 2002 WRX
