Subaru Tech All We'll Drive
Tial BOV
Old Jul 21, 2006 | 11:12 AM
JonLGT's Avatar
Just for decoration
Default Tial BOV
I found one on Gruppe-s.com it says for wrx/sti but does anybody knwo if it comes with a flange for the TMIC? thanks.
Old Jul 21, 2006 | 11:28 AM
Franklin's Avatar
Call them and ask?
Old Jul 21, 2006 | 12:16 PM
BrewPuBeaver's Avatar
*Big Schpellar*
it does not. you have to order it seperate, or have one fabbed. also the spring you need is the lowest one possible, and it still might not be low enough. normally PDXTuning swaps them out for their own custom set up spring rate. i am going this route, seems my BOV (worx) is prone to compressor sube on higher HP applications.
James you reading this?
Old Jul 21, 2006 | 12:31 PM
JonLGT's Avatar
Just for decoration
How about the Sard? is it flanged?
Old Jul 21, 2006 | 03:06 PM
Alizarin's Avatar
Gravel fiend
That's quite interesting, Dave... You mean it doesn't open fast enough (or flow enough) at high pressures? I doubt I'd ever be running high enough boost to make it matter, but I will keep that in mind.
Old Jul 21, 2006 | 03:32 PM
813_05_STi's Avatar
Am I OG Yet ?
My Tial bov came with the flange? Theres even a incert in the foam packing inside the box for the flange.
Old Jul 30, 2006 | 09:24 AM
AvASTi's Avatar
I use a Mad scientist
jon get the sard r2d2 that biotch is bad ass that is the one i wanted but just didnt wanna wait......
Old Jul 30, 2006 | 12:08 PM
AvASTi's Avatar
yea............check out the last sentence james.....
SARD R2D2 (RACING BLOW OFF TWIN DRIVE TYPE 2) An aluminum die cast part ensures a super lightweight & compact body. The air capacity of the air chamber increases by having air jackets all around the cylinder valve. A large opening nozzle improves air discharge efficiency, and facilitate the tuning of the intoxicating & addictive blow-off sound. R2D2's air sealing reliability is tremendously improved by integrating the valve & the shaft design. This design also make the R2D2 BOV more compact & lightweight which also equates to a more affordable price.
* Adjustable BOV Spring Load - Ensure that the BOV doesn't leak at idle
* Nomex Seal - Ensures tight piston seal to warrant against leaking
* Twin Drive - Maximum venting and Great Sound
* Blue SARD Racing Silicon Hoses included
* SARD Parts Bag containing Hose Clamps, Zip ties and T-Piece
* Designed for street cars to high boost track cars!
