Subaru Tech All We'll Drive
Boosting Question.
Old Jul 19, 2006 | 03:08 PM
cpages2's Avatar
PWN5 J00
Default Boosting Question.
I took the car out for a quick drive and soem gas. I hadnt really drivin sporty in a while so I thought I would open her up a bit. Well I notice that I am only hitting .8 Mpa (OEM Boost Gauge) on the boost gauge in 4th/5th gear at WOT.
I know in the past its almost touched .1, And according to my math .8 Mpa is around 11 PSI, but I thought the stock WRX ran almost 14PSI.
All I have done is SPT Catback and K&N Panel Filter.
Ohh I also did an ECU reset a few mins. ago and the car seems to boost quicker but still wont pass .8 Mpa.
- Mike
Rally driving, when you're fertile enough to impregnate women with eye-contact
Old Jul 19, 2006 | 03:25 PM
cpages2's Avatar
PWN5 J00
I re-installed the OEM boost Gauge.
I thought if it was leaking the preasure would bleed off.
Whats the best way to check for leaks?
Old Jul 19, 2006 | 03:31 PM
cpages2's Avatar
PWN5 J00
how does one make a home made leak tester
Google search did nothing for me.
I checked everything and it seems good.
Old Jul 19, 2006 | 03:37 PM
cpages2's Avatar
PWN5 J00
im gonna check. Will I hear something (like air whistle) if its leaking?
Old Jul 19, 2006 | 03:54 PM
cpages2's Avatar
PWN5 J00
well the 2 clamps on the IC were a little loose so I tightned all the way down. The Y pipe was really really tight. And my boost gauge cable seems dead on.
I will take her out in the morning and see if she is any better.
Thanks,
Mike
