Boom*.... Waiting leak down test`s
I got mine for $220 with a mild steel flange and a 9lb spring. I traded the 9lb for an 11lb since I'm going to be running the APS BOV with the Tial. My friend got his at Automotive Engineering for $200 with an aluminum flange.
You're going to need the 9lb spring cuz the 7lb will open at idle and since you have a MAF that wont work.
Guest
Posts: n/a
As long as you dont have more than 9psi of pressure drop between the IC pipe and the intake manifold
There should only be like 1-3psi drop. 28psi at the manifold is about 30psi in the IC pipe by the throttle. So you'll have about 30psi on the bottom and 37psi on top.
Guest
Posts: n/a
Nope, you could either cut off your flange or add the Tial with the Worx. Since it has a 50mm piston it wouldnt work as well if it was a bolt on cuz the stock hole isnt 50mm.
Adding the Tial might be a better idea since you can fully recirculate the Worx and vent the Tial. The car may run better than it would if you had just the Tial.
I know what surge is. I know that surge puts stress on the thrust bearing and thats why a BOV is good to have, but I took apart a BB turbo and it didnt have a thrust bearing. My friend had told me that since a BB turbo doesnt have one a BOV isnt needed.
What happens when the wheel "stalls" that would cause the seals to go, other than thrust bearing failure?
