More suspension/driveline parts....
I followed the advice of fatagel and picked these endlinks up to go along with my recent sway bar install. While I was at it I got the steering rack bushings. I have only seen a few posts about these, all of which have been good reviews. I will post some feedback after the weekend.
Originally Posted by KAX
i didnt notice anything with the steering rack bushing. a huge PITA for minimal if any improvement.
the other part though are the subframe lock bolts. those, when you can get them, are nice.
Originally Posted by fat angel
although on a second note; with the way you drive you might feel a difference.
Install was done today. Huge thanks to Fat Angel for the hard work!
The first thing was to change out the end links with the whiteline adjustables. The stock ones are steel, but one look at how sturdy the whitelines are, it made it a no brainer.
After that was out of the way it was on with the coilovers
We had to make some adjustments after the inital test drive. The car with the current setup is very connected in every aspect. Take a look at how the entire car went on the side when we were only trying to jack up the one front wheel.
We made some minor adjustments and I did another test very short test ride. The car with these on the softest setting rides smoother than stock, but is more stable in the corners. When it is set on "5", it feels like a shifter cart. An alignment is in the very near futre. This is what the final stance looks like.
