Building 2.5 engine
Building 2.5 engine
I'm going down to Mastro to pick up a 2.5 short block and some other crap.
I trying to decide if I want performance cams, and which ones to get?
Let me know what you guys are running. I post up some more info on the build as start tearing down the 2.0.
'02 Subaru WRX 2.5L, SR40 turbo, MRT TMIC, RA gears, ACT clutch & flywheel
'06 Chevy Cobalt SS GM Stg 2 G85 lsd
'94 Acura Integra GSR sold
'99 Isuzu Rodeo 4x4 2" lift, Procomp 9000 shocks, 20" Procomp Knight Khrome wheels sold
'92 Acura Integra RS sold
'04 CRF450R '86 TRX250R
Do you plan on doing headwork as well? I went the cheap route (if $4600 parts/labor is cheap) and kept the stock wrx heads with the 2.5 shortblock. I had no problems running a DB20G with that setup. However, if you plan on a larger blower, I would atleast port the heads and do the TGV delete as well. I was afraid if I wanted to go bigger than a 20G, I would end up floating the valves eventually. Good luck!
There was a thread about a guy who welds the TGV holes and then ports it out for over 100 more cfm of flow, $185. Yeah I am considering getting a bigger turbo the SR40 isn't great imo. How do you like the 20g, is it the TD06? IF my heads are still good I will probbly not get the rest of the stuff, if the need work I will get the tgv ported, helix cams and valve train and some forged valves.
The thing that bothered me the most is I never got a sign, not a CEL or over heating nothing. I was trying to buy a DR725 from my friend, I want to get rid of the MRT TMIC. What do you run now Mantra?
Unfortunately the car is sold. I was still running an MRT TMIC because I desired instant throttle response and little lag as possible from the 20G with an TD06 hotside. Full spool (20-21psi pump gas)was around 3300 -3400 rpm holding to about 6700 rpm's then tapering to 17 psi. I wanted to save the life of rings, especially being setup for roadcourse duty. Alky injection was next on the list until the reality of being self employed hit me like a ton of bricks (IRS and Taxes). So the toy had to go.
Well that sounds pretty good, maybe I ll keep the top mount and do a water or Cryo sprayer. I will probably wrap the new header, uppipe, and downpipe. And maybe the turbo too.
Guest
Posts: n/a
