ordered my aem uego today
Guest
Posts: n/a
i order my aem wideband today. already got my source to have the new o2 bung welded. anyone have experience installing this in a suby? what am i in for? do i just need to run the new sensor and then hook up the power and groud wire??
any help will be appreciated
Originally Posted by BrewPuBeaver
call me for insider info....
the aem is a good wideband, but they're all the same to install for the most part.
Guest
Posts: n/a
Originally Posted by fat angel
so what's the secret handshake? if it's inside why not pm?
secret handshake
depending on what downpipe you have, and your setup, it is doable to not have to remove it. you pretty much want it past the bellmouth. iirc you have that txs dp, so look for the skiiniest part(about a foot +or-, you can 6" or closer hell) and that's a good spot for the bung. you ever see a downpipe that came with a bung there already? if you think someone could fit in there to weld, then stop in and ask. i can't see your clearance so it's hard to say.
the aem is a good gauge. if i went with one there are only 3 i'd even think of, and that's one.
Guest
Posts: n/a
