Subaru Tech All We'll Drive
Tuning question?
Old Apr 11, 2006 | 06:41 PM
blacksleeper's Avatar
Giggity Giggity Gone
Question Tuning question?
If I were to install a vf39 turbo, tmic, injectors, and fuel pump, would I be able to drive it somehow to get it to scott to tune the car(when he comes down)? can he send me a base map of some sort? How would I go about doing this?
Old Apr 11, 2006 | 06:43 PM
i forgot to mention i have ecutek set up for tbe and uppipe.
Old Apr 12, 2006 | 02:29 AM
Frankie Figs's Avatar
Too Much is ALMOST Enough
You can mail-in your ECU and get a base map. Then you can have it fine tuned when Scott comes back
Old Apr 12, 2006 | 05:00 AM
there is no other way? i really cant afford any down time....its my only car.
Old Apr 12, 2006 | 05:01 AM
what if i held off on the injectors till i met up with scott? then i would install them in the parking lot before he tuned the car. would that work?
Old Apr 12, 2006 | 05:50 AM
You can overnight the ECU to him and then he can overnight it back. That would be like 2 or 3 days of downtime. Scott makes a map, you mail in your ecu, he flashes it, and mails it back. BAM 3 days at the most. You could send it out as we're installing everything.
Old Apr 12, 2006 | 06:15 AM
MF-DIF's Avatar
spooled@12mph
You could be ok if you stay out of boost and just creep around under 3k.
Old Apr 12, 2006 | 07:15 AM
alright well when the time comes I will let you know what I will do....thanks though for the help and advice...and frankie i sent you a pm about the fp green.
Old Apr 12, 2006 | 07:43 AM
Not with bigger injectors.
Old Apr 12, 2006 | 08:06 AM
Apexi wrx's Avatar
The NExt Brian O' Conner
scott has an extra ecu he can send you
Vroommm psshhh
