Subaru Tech All We'll Drive
lube a bov???
Old Mar 13, 2006 | 03:40 PM
byerly0137's Avatar
Default lube a bov???
i have a turboxs bov and have had on my car for about 25,000 miles. i was reading in a forum that you are supposed to lube it abotu every 6,000 miles, is this true? i know this is probably a dumb question but i have just never heard of doing this. if so, what do i lube it with and how? thanks for any info.
Old Mar 13, 2006 | 04:08 PM
byerly0137's Avatar
like what kind of thin oil, and where can i purchase it. also how do i do it, just spray it in where the valve is located? im clueless towards that part...
Old Mar 13, 2006 | 04:59 PM
Alizarin's Avatar
Gravel fiend
Originally Posted by fadedSTi
take it apart to lube it. you may want to check with the company that made the bov to see what oil they suggest
For instance, the Worx tuning BOV that I (as well as Faded) have is supposed to be lubed with assembly lube. I have a big ol' tube of the graphite based stuff that I use when lubing it up.
That sounds soooooo kinky.
Old Mar 13, 2006 | 05:43 PM
byerly0137's Avatar
ok so where did u guys buy it at
Old Mar 13, 2006 | 08:46 PM
Apexi wrx's Avatar
The NExt Brian O' Conner
i used dw-40 no prob for me i cleaned it first then used and clean the drip
Vroommm psshhh
Old Mar 14, 2006 | 11:02 AM
Alizarin's Avatar
Gravel fiend
i should do mine. i have never done mine. ive owned it over a year
You're supposed to do it after the first... um... 3k miles? Then every 10k after that. I think. I can't remember, but I need to do mine too.
