white smoke?
so i went to the shell on ehrlich yesterday to get my oil changed, and figured since its like my third time i'd clean the engine out(flush). so i'm watchin these guys work on the suby and i was scared but it needed to be done, anywho i go to leave and wash my car and its over there idling while im getting some change well, i look over and she is spitting out white smoke? so i was like wtf? i called a couple buddies no answer finaaly to one buddy that says its normal. but he drives a busted crx!!!!!! can u guys please help me here is this normal for and engine flush.!!!!only when im idling and i revvv it up not while im driving. thanks guys!!!!!!!!!!!!!!!!
"White smoke" when the motor is "cold" could be just water vapor. My car does it in the mornings when the temperature is < 70 degrees or so.
If its thick white smoke, that's coolant burning. But that would probably happen all the time.
Sounds to me like just water vapor. Does it goes away when the car warms up?
Originally Posted by 23240sr
how do you treat the turbo on there??
Originally Posted by 00eclipseGT
So if my car blows out white smoke thats not thick , my turbo seals could be goin bad?
Originally Posted by smittyjasIII
all depends man, oil in a turbo car can be getting burnt anywhere, there are so many things that could be doing it this is what my uncle says. he works on all the aftremarket work mastro does. he is in drew park at the end of grady headin north.advanced auto repair.check it out, cause i have no clue.
dont say that the turbo cant be bad because it only has 50,xxx on it...my buddy up here has an 05 wrx and the turbo went bad...i dont know why, but it happend..and it smoked...my turbo is bad on my sr, and it smokes occasionally...not when im running it or driving it, but when it idles...sounds like your prob to me.
12.8 @ 105
12.8 @ 105
