Subaru Tech All We'll Drive
What times and hp are possible with this setup?
Old Feb 16, 2006 | 05:22 AM
blacksleeper's Avatar
Giggity Giggity Gone
Question What times and hp are possible with this setup?
I have an 03 wrx with up, down, tbe, k&n drop in, and ecutek road tuned by ss. What are the fastest times someone has run in the 1/4 with this setup, and what does it usually dyno at? Just wondering........
Old Feb 16, 2006 | 07:38 AM
platinm's Avatar
I had that setup plus the fuel pump and put down 241 HP and 227TQ.
Quarter time was 13.7 at 95
1.8 60'
Old Feb 16, 2006 | 08:05 AM
schoellnasty's Avatar
1.8 60'
Thats a low trap for a 13.7. Hell my stock car traps 92 and I cant drive . From what Ive seen a car with those mods should go mid 13s with a trap in the high 90s. If you drive the hell out of it, then low 13s at just over 100.
Old Feb 16, 2006 | 09:18 AM
platinm's Avatar
I only ran my car a handful of times with that tune. I'm sure with a little more practice, I could have hit my goal of 13.5 at close to 100.
Old Feb 16, 2006 | 11:38 AM
well we'll see what i can do cause i am going down there tonight.
Old Feb 16, 2006 | 11:55 AM
AvASTi's Avatar
I use a Mad scientist
i know mine isn't shit i have an 02' wrx tbe thats it with a burnt clutch i ran 14.3 and barely launched so with all that u better break mid 13's or something is wrong am i correct is it just the one behind the wheel?
Old Feb 16, 2006 | 11:56 AM
AvASTi's Avatar
Smile
and oh that was 14.3@93.2mph sorry!!!!!!!!!
Old Feb 17, 2006 | 04:22 AM
well i am very disapointed to find out that i ran a 14.3, 14.2, and my best of a 14.0 with a 1.9 60'. so i am going to have to have scott fix the problem because my friend who has the same setup with an accessport was running consistent 13.5 every time. then i thought it was me, but we went from a 60 roll twice on the highway and he pulled on me by at least a car maybe two by then end of third gear. so something must be wrong with my tune. so im gonna call ss and im sure he'll correct the problem.
Old Feb 17, 2006 | 04:23 AM
actually i ran better times with just a tbe and a manual boost controller. 1.9 60' @ 13.9 and trapped at 96-97
Old Feb 17, 2006 | 04:53 AM
platinm's Avatar
Keep in mind that you also don't have a larger fuel pump. You are probably starving the injectors. The larger fuel pump pushes the injector duty.
