Subaru Tech All We'll Drive
help me out on which bov
Old Feb 9, 2006 | 06:26 PM
byerly0137's Avatar
like the sound is really long and it sounds like the mopar bov on a srt 4. maybe i was listenin to the wrong one. do you have a sound clip?
Old Feb 10, 2006 | 12:04 PM
byerly0137's Avatar
how does the worx compare to a hks bov
Old Feb 10, 2006 | 05:48 PM
MF-DIF's Avatar
spooled@12mph
I crushed my OE BPV. Wacked the top a with a hammer a few times, you can use a vise if you prefer. Holds 19psi all day long.
Old Feb 10, 2006 | 06:25 PM
byerly0137's Avatar
what do you mean crush the oe bpv?
Old Feb 10, 2006 | 07:45 PM
  #18 (permalink)
StiGuy's Avatar
4 doors & 6 on the floor
Oe = Original equipment
Bpv = By pass valve i.e. blow off valve
Crush = Crush with whatever blunt object you prefer. As MF-DIF stated below generally a hammer but a vice is better.
This quote speaks about Dsm(s) but the principle is the same:
"Owners of highly boosted cars have discovered that the stock 1G BOV tends to begin to open too early. This causes a pressure leak in the intake system that limits boost. The valve tends to leak somewhat at lower boost levels, then opens fully when it's supposed to. This low-level leakage is the problem. "
So by crushing the stock bpv you're limiting how much it'll open, which in turn will allow higher boost levels.
Old Feb 12, 2006 | 01:36 PM
  #19 (permalink)
byerly0137's Avatar
anybody on here using the GFB stealth or hybrid bov. i assume it does the same as the worx 1.2 bov but it makes a little better sound. anybody have any problems with this bov.
