help with Turbo timer
the Apexi turbo timer A/F is not displaying anything on the screen just the two lines i do wait until the car gets warm too. I think I put the O2 senson in the wrong place. What one should i us
rear
- Rear o2 sensor
- heater signal
front
- front o2 heat sensor
- a/f sensor +
- a/f sensor -
- a/f sensor shield
Thanks
rear
- Rear o2 sensor
- heater signal
front
- a/f sensor +
- a/f sensor -
- a/f sensor shield
Thanks
idont most people have problems with that? to be honest it wouldnt even be worth trying to hook up (not to hate or anything) but it wouldnt be accurate. although if you really want to hook it up, it would need to be on the front o2 sensor.
Guest
Posts: n/a
Originally Posted by JonWRX
Never even heard of a TT that you would need to touch any wire except brake saftey, rpm, speed sensor and ignition.
The Suby o2 sensor is a wideband o2 (reads 5 volts) 95% of all cars use a narrowband (reads 1 volt) The APEX-i TT will only read upto 1 volt, so even if you hooked it up right it wont work.
thanks for your help i did not know that it will not read over 1 volt that sucks. Then there is no point with it then.
I drive a Blue 2003 WRX in live in the west side of bradenton and drive every day down 41 to sarasota
