Subaru Tech All We'll Drive
Your thoughts on these products????
Old Nov 30, 2005 | 02:16 PM
JonLGT's Avatar
Just for decoration
I would probably get the Cusco Heat shield but the others I wouldn't worry about until further down the road.
Old Nov 30, 2005 | 02:51 PM
javasti's Avatar
Tampa Stock
bling factor
Old Nov 30, 2005 | 03:24 PM
byerly0137's Avatar
nofearnick just put the cusco heat shield on his car, you should ask him about how it works and the looks
Old Nov 30, 2005 | 05:29 PM
Alizarin's Avatar
Gravel fiend
Originally Posted by fadedSTi
exactly. its not needed Will. i dont have a heatshield at all with my GREEN
Because you have a FMIC, and don't have to worry about heat soak with a TMIC. I would recommend either a turbo blanket or a heat shield if you have a TMIC. Any prevention for heat soak you can get is good.
Old Dec 1, 2005 | 01:47 AM
813_05_STi's Avatar
Am I OG Yet ?
That Intake Manifold will hurt your low end big time and with your mods its just a waste of $$.. I remember you saying you wanted to make the car faster and you keep looking at odds and ends that are high dollar and wont get you squat. You mentioned that the car was tuned and I asked you what management you had and you diddent know. I would take the car to Mastro and have them check your ecu and see whats up. You have a good platform to make the car much faster for little cash. With a 255 pump, ecutek reflash, avcr or esbc from pdx and i bet you would see a world of difference. That package I just listed is right around a grand. 290-315whp range with your turbo back, header, cold air..
Old Dec 1, 2005 | 03:19 AM
BrewPuBeaver's Avatar
*Big Schpellar*
^^^... what are your goals? power wise....
if you just want more power and you want that power during the whole power band...
i would suggest that you look at some staged kits. that way you save money in the long run and if you buy it from a certain shop you will have a resouce for asking questions.
http://www.pdxtuning.com/store/showc...?categoryid=11
look at this and tell us what you think would suite your needs power wise, then tell us what fits in your budget
Old Dec 1, 2005 | 05:28 AM
Wukindada's Avatar
What are your mods to date? Budget for new mods?
