Subaru Tech All We'll Drive
What are the benefits of an aftermarket BOV on STI?
Old Oct 14, 2005 | 12:16 PM
fathead's Avatar
I'm aLL mOtOr I sWaRe ;)
cool sounds....
RIP Kevin "Slo_Si" You'll be missed by everyone who knew you my nigga.... I'll see you soon man...
Old Oct 14, 2005 | 12:24 PM
platinm's Avatar
For your current setup, not much is to be gained. If you start running over 20 lbs. you might want to start thinking about an aftermarket one.
Old Oct 14, 2005 | 12:26 PM
Franklin's Avatar
Originally Posted by fathead
cool sounds....
That pretty much sums it up. Aftermarket BOVs aren't needed unless you're boosting beyond 20lbs.
Old Oct 14, 2005 | 04:49 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
at around 18 it will start leaking, thats when i would upgrade to a tial or something of that nature. DO NOT BUY A TXS RFL!!!!!!!!
Old Oct 14, 2005 | 11:34 PM
DubtecV2's Avatar
...in da hause!!!
I'd go with a Turbonetics Raptor...just personal reasons
Old Oct 15, 2005 | 02:41 AM
I like my APS dual vent. Since I'm not going to be running a MAF I'll probably get a Tial.
Old Oct 17, 2005 | 08:02 AM
byerly0137's Avatar
What is wrong with the TXS RFL? I have and nothing is wrong with it, its a good bov in my opinion.
Old Oct 17, 2005 | 08:05 AM
DubtecV2's Avatar
...in da hause!!!
From what I've read, it's known to leak in moderately high PSI uses.
Old Oct 17, 2005 | 09:29 AM
rv7's Avatar
rv7
Pros= sound
Cons= runs rich everytime you make it blow off, unless you set it up for 100% recirculation, in which case you might as well use your stock BPV.
In short, your MAF (airflow sensor) meters the air and injects fuel for that air, however the BOV (if set up to dump into the atmosphere as they normally are) gets rid of most of that air, which means that there is too much fuel (rich) being injected into the cylinders. You will see no performance gain from running a BOV.
