Bat Overlays
Guest
Posts: n/a
Originally Posted by esemes
+1
didya have any troubles turning the corners with these??? the cheapie ebay ones went on without heat, but these needed to be warmed/softened to make the turn.... i messed em both up, and am redoing....
i dunno.. i've done all kinds of vinyl installs, but rounding the curves on these was a challenge for me....
ese
ese
thnx.....
yep, i have a spraybottle w/ soapy water for all my vinyl installs, too....
will try to have more patience this time around (third timesa charm...right?)
JONWRX- if you dish me 15$, i'll order ya a pair tonite.
i must know for sure by sat nite/sunday morn.
just verify which pieces (and how dark) you want.
ese
ese
www.gsxRpaddock.com <---gsxR research, solutions, & support
www.iWSTi.com <---STi research, solutions, & support
www.TOPSPEEDsales.com <---STi premier tuning and performance
oh yeah, installed my cooling feed inducer plate (with TS logo!) yesterday....
now THAT's the type of installs i prefer..lololol
Overlays look cool.
As far as camber goes.... in the first pic it almost looks like + camber. I'm sure some of that is just the angle but u could deff. use a bit more. Look at your align. specs on the sheet they gave you with your align, you want at least -2.0 if not more, say -2.5. But not more than 1 deg of difference between the front and rear so you are somewhat limited by how much you can get outa the rear without camber plates in the rear. Follow me?
