Subaru Tech All We'll Drive
FINAL help needed to get car running, pics inside
Old Oct 3, 2005 | 06:38 PM
marksaccord95's Avatar
TR Registered Member #5
Default FINAL help needed to get car running, pics inside
1)the vacuum line that comes off the bottom of the TB goes to the BOV right?
2)the harness for the starter to battery, the ground strap with this bracket on the starter side goes to?
3)connector in my hand by the fuse box goes to?
4)wire my thumb is on that comes out of the fuse box goes to?
5) plugs by fuse box. green goes to the pump for the windshield washer, white one goes to?
6)this is on the back right hand side of the motor, almost above the starter. the big vacuum line goes to the tube that runs accross the front of the intercooler, where does this smaller one go?
thanks for any help
http://www.floridaracing.org
Old Oct 3, 2005 | 06:40 PM
so close, after i get it running im going to clean everything up.
Old Oct 3, 2005 | 07:37 PM
QuickOne's Avatar
It's soooo stock?
Need hoes clamps on the intake do you.
Old Oct 3, 2005 | 10:27 PM
yea i gotta go to advanced tomorrow to get that and a few other misc things.
Old Oct 4, 2005 | 03:33 AM
BrewPuBeaver's Avatar
*Big Schpellar*
almost there
Old Oct 4, 2005 | 04:06 AM
M249SAW's Avatar
Firemedic / Local 4420
The BOV vacuum hose attaches to a nipple on the intake manifold.
Attached Thumbnails FINAL help needed to get car running, pics inside-hose.jpg
Old Oct 4, 2005 | 04:20 AM
M249SAW's Avatar
Pic #4 eyelet goes to the stud on the positive battery terminal.
Pic #3 is two wires with a lock washer are ground wires that bolt to the fenderwell (see highlighted part in pic)
Attached Thumbnails FINAL help needed to get car running, pics inside-wire.jpg
