cheapest mod with best results
Originally Posted by fadedSTi
what is the cheapest mod that you can buy for your suby that make a really improves the performance? suspension or engine mods
i personally think the ebcs for $90 is amazing
I would have to say bang for the buck would be sway bars...
Guest
Posts: n/a
Originally Posted by BrianB
They only problem is if you do not get tuned for the EBCS you will be overboosting... this also goes for any engine mod.
sway bars i hear really make a huge difference on the suby's. good ones can be pricey though
very true. will require couple hours of tuning to get full potential and to be safe with it.
Front= $170.00
Rear= $220.00
Get one at a time or combined for $390.00
doing the sway bars, may as well do the endlinks to do it right. the list never ends. never a cheap way out of it.
When you upgrade the rear sway bar, you should also upgrade the stock sway bar mounts. You can get the STi rear sway bar mounts for about $15, IIRC. The stock ones tend to bend when subjected to the strain of the upgraded bar. It kind of defeats the purpose of the upgrade. Either that or spend the $90 to get brand name mounts.
Kartboy SS and bushings or the 20m STi RSB/brackets/bushings for me. Each was about $120 and completly enhanced their respective areas.
SnowMan tuning
SnowMan tuning
ecutek base flash.
best BFTB go-fast(er) mod.
stock endlinks are good enough, eh?
hmmmmmm
hmmmmmm
www.gsxRpaddock.com <---gsxR research, solutions, & support
www.iWSTi.com <---STi research, solutions, & support
www.TOPSPEEDsales.com <---STi premier tuning and performance
