Subaru Tech All We'll Drive
Clutch Suggestions
Old Sep 20, 2005 | 01:49 AM
weverb's Avatar
ACT has another flywheel that is not as light as 9.6lbs. It is closer to the Exedy.
There are a couple of people who driveshafts for the WRX and STI. There is a one piece carbon fiber one that is about $1500 . I am thinking the Drive Shaft Shop's 1 piece aluminum for $425.
Old Sep 20, 2005 | 04:03 AM
BrewPuBeaver's Avatar
*Big Schpellar*
i would recomend to clean up the stock fly wheel and to get the Perrin light weight pulley instead.
Old Sep 20, 2005 | 04:40 AM
weverb's Avatar
I thought the pulley caused other problems also.
Old Sep 20, 2005 | 04:45 AM
*Big Schpellar*
if you have both it is like over kill and your engine will not be able to work well with the ECU. some flywheels do it, never heard of just a pully to cause problems, unless you go underdriver, witch i would definatly not recomend
Old Sep 20, 2005 | 05:07 AM
weverb's Avatar
What gain/benefit does the lighter pulley give you?
From what I have read so far, the 13.9lb flywheel could cause false misfire codes on WRX's due to only 1 cam position sensor. The Sti has 2 and will not throw a code. All the more reason to replace my 109k+ stock motor and tranny with JDM pieces. I just need to ditch the poor stuff they original stuffed in the car.
Old Sep 20, 2005 | 05:28 AM
  #17 (permalink)
*Big Schpellar*
with a lighter pully you are lightening the rotainal mass. there is a formula for the exzact % ratio`s. but it is something like every 1 lb of rotainal mass that is lost, is = to almost 4-5 whp...
you could do a replacement flywheel that is very close to the stock weight, just a little bit lighter. not 50% lighter. and since it is closer to the stock weight you would be able to have a beefier flywheel. but personally i have nerver had one. but i have seen a good improvemt with the perrin pully. but it is something that you might have to tweek a little something here and there with your tune.
Old Sep 20, 2005 | 04:51 PM
  #18 (permalink)
smooth_ej20's Avatar
aftermarket crank pulleys have a tendency to throw off an engines harmonic balance which wont cause any big problems right away but will just mess up the engine over time.
