part needed::: subie brothers, please helpmeh..
TTwins are my fav
on
brethern.......
i am in need of a paret/number 9or heck, the part itself is fine, too) for my 06 sti.....
i need the steering column cover, for the sti/2006/wrx/etc. to replace the one i have on there now. when installing the laamco boost gauge, mastro (following the instructions!) placed it on the opposite side from the 05's gauge, and i definitely do NOT want to keep it on there. it blocks the outside temp, and partially the fuel gauge (the important bottom ¼-E portion i need to see!). prior, on my 05, they located it on the RHS of the column, and it blocked absolutely nothing. perfect. guess i was expecting this again, and am unhappy about its location now.
i dont believe they did anything wrong, as the instructions state to put it there, but it is a thorn in my side by blocking so much stuff...
can anyone help me get the oem top cover, so i can relocate the pod to the RHS instead?? it'd be a lifesaver.
thnx much
-ese
ps- i am not faulting mastro on this; they did great work installing all the stuff on the options list; i just wish i wopulda known that the last gauge was installed on the rhs which is against the directions......
thnx much
-ese
www.gsxRpaddock.com <---gsxR research, solutions, & support
www.iWSTi.com <---STi research, solutions, & support
www.TOPSPEEDsales.com <---STi premier tuning and performance
Okay first you little weasel where did you get the logoed mats from?
IF this is still the same as it was on the '05
p/n: 34341SA030JC
Name: Cover Ay Col
List: 29.42
All of this was from 07/2004 when I removed my boost gauge. And yep doing a quick search Wilkins Subaru still shows this same part number on 07/18/2005 here: http://forums.nasioc.com/forums/arch.../t-742943.html
Not that you need it but if I recall correctly it is both the bottom and top parts.
Hth
Oh btw if you don't want it I'll gladly take that drilled cover off your hand.
Also btw btw my boost gauge was also mounted on the lhs from the factory.
p/n: 34341SA030JC
Name: Cover Ay Col
List: 29.42
Hth
TTwins are my fav
on
p/n: 34341SA030JC
Name: Cover Ay Col
List: 29.42
Hth
p/n: 34341SA030JC
Name: Cover Ay Col
List: 29.42
Hth
i bought an extra set back in 2004 when i heard they were going to be changed to the plain type..... sat on them for nearly a year....lol
hey... did your have the pod mounted on the RHS???
thanks for the 4-1-1
ese
so where is the problem of having a little tiny whole on that peice of plastic??? dust damage? why dont you move it yourself. it isnt very hard to do. mech gauge right? just a vac. line and a power and maybe a ground. depending on what brand gauge.
TTwins are my fav
on
Originally Posted by M249SAW
Scott if you want I can order it for you at the wholesale price.
Let me know
Kyle
Let me know
Kyle
will-do today.
thanks
Brew-Pubeeav- im ordering a new piece as there are holes drilled in it.
Let me know
Kyle
Let me know
Kyle
Watch for a while and you'll understand I think you could call it an Ese'isim
TTwins are my fav
on
hey...wait........ the car has 400 miles on it... gimme a break already!
ese
ps- it's two holes... visible to me at all times, on an otherwise holeless surface... (my attempt at humour)
pss- thanks kyle, for researching this for me and offering a viable solution. i feel much better about it all now. another good expereince with my 06 (and many more, i hope!)
