Subaru Tech All We'll Drive
Pros and cons
Old Aug 30, 2005 | 07:17 PM
fresh&clean's Avatar
I love Lamp
Default Pros and cons
What are the Pros and cons about the boxer engine and the top mount intercooler?
Old Aug 30, 2005 | 10:06 PM
2TurboImports's Avatar
sooo...where's the turbo?
light weight, small, lower center of gravity.
there are cons??? lol
Old Aug 31, 2005 | 03:30 AM
BrewPuBeaver's Avatar
*Big Schpellar*
these are just MY opinion.
cons:
since the exhaust is right next to the pasenger cylenders, they get very hot and are more like to throw a rod on that side.
everything is very compact. so if you are doing something simple, it is almost worth the time to take everything off just to make it easier to get your hands where you need them.
now that all of the turbo`D suby`s are 2.5L all of the 2.0L will be very cheap.... this is both a pro and con.
Pros:
Turbo!!!
the way the engine is set up, there is a lot LESS resistance and friction as a whole.
lots more
Old Aug 31, 2005 | 04:36 AM
davcivic's Avatar
El Mas turboso
The only cons I can think of is the space, hardly any to work on the car, like he said, you might as well take everything off. But the basic changes, alternator, ac compressor, are really easy to do.
The engine is great, balanced is perfect and the configuration of the engine and transmission is awesome. It's mounted like a V8 kind of, the only thing is weak parts on the WRX. If they where built stronger, or if we build them stronger they would be one of the best 4cyl engines to modify.
Just look at the JDM Sti engines, they can hold insane amounts of boost and will run perfect. The USDM Sti is also a great example of a well built engine/car. The WRX I believe was never thought of being so big, and that is why is was like a test car for the possible introduction of the Sti, and I'm glad they did being them over.
2002 Subaru WRX
1988 Honda Civic Hatch
Old Aug 31, 2005 | 04:41 AM
DubtecV2's Avatar
...in da hause!!!
Pros: everything
Cons: nothing
Old Aug 31, 2005 | 04:56 AM
I'm Slow's Avatar
I'm Slow
cons:
Very true! I also see the TMIC as a pro and con. The pro is minimal lag......the con is Heatsoak like a mf! Also the major con of the WRX engine is the weak internals!!!!!!!!!!!
Old Aug 31, 2005 | 07:15 AM
mantra1's Avatar
Shaggin' Wagon IV
If your going to modify, go right for the STi. The WRX motor does not like too much power, especially with cast internals.
TMIC will heatsoak in traffic and after repeated hard runs. Just get an intercooler sprayer to keep things cool
