Subaru Tech All We'll Drive
02-03 vs 04-05 WRX motor differences?
Old Aug 29, 2005 | 11:06 PM
marksaccord95's Avatar
TR Registered Member #5
Default 02-03 vs 04-05 WRX motor differences?
is there any difference between a 03 to the new body style 04 motor? hence, if i bought an 04 motor to put in my 03, does anything change?
http://www.floridaracing.org
Old Aug 30, 2005 | 04:49 PM
scoobywrx's Avatar
I am almost 100% sure there is no difference.
Snowman Tuned
Old Aug 30, 2005 | 05:12 PM
davcivic's Avatar
El Mas turboso
no
2002 Subaru WRX
1988 Honda Civic Hatch
Old Aug 30, 2005 | 06:37 PM
Opie's Avatar
So now I'm a liar...
Same basic longblock, but you should transfer the wiring / intake manifold / sensors, etc from your original block as some small things (like sensor location and style) have changed.
TR...where details aren't important if leaving them out makes the story bettAr!
Old Aug 31, 2005 | 03:31 AM
BrewPuBeaver's Avatar
*Big Schpellar*
like Opie said there are only minor differances... like location of bracket mounts for stupid shit that i dont understand why they would change it.....
Old Aug 31, 2005 | 03:40 AM
*Big Schpellar*
Old Aug 31, 2005 | 04:30 AM
davcivic's Avatar
El Mas turboso
Is this a I want better performance question so should I get the swap??
If so, not it is the same, less miles will mean a stronger motor, but that's about it.
If it is a I got an 03 shell or a car with a blown engine and can only find an 04 used engine will it work kind of question, then it will work, but like they said they might be different sensor locations. If they are the same sensors just in different places you can always extend the wires of your factory harness, not too hard to do, as long as they use the same plugs you have no problems really.
Now if you are talking about the 04 sti engine, that's different.
2002 Subaru WRX
Old Aug 31, 2005 | 05:01 AM
I'm Slow's Avatar
I'm Slow
Mark, the 04 engine is the same and only minot differences like what was mentioned above. You could definetely figure it out Mark. But If I were you I would get a STi motor if you are buying new......or get a 06 WRX motor....2.5l!
Old Sep 1, 2005 | 06:50 AM
*Big Schpellar*
crawford s2 kit
