heres what i could look like
fishing line is the easiest way.
checkout my music at
http://www.myspace.com/singularismusic
my biz http://www.suncoastexpressinc.com
i did my front badge with fishing line. use 8lb test slides right in. the center of the badge has a notch that juts out on top and on bottom. start on one side work towards the middle then when you hit the notch start on the other side and work towards the middle then you will be able to pull the badge right off. if you need help let me know. it's the first thing i did to my car when i got it 2 years ago (i do have some knowledge of our cars). i even made the original badge into a belt buckle (sometimes i get in a crafty mood)
sheldon
sheldon
