egt gauge
James, if you want an accurate reading of egt's, tap the exhaust mani or uppipe. There is about 180 degree difference between pre and post turbo exhuast temps (pre being higher, of course). Also, get atleast a 52 mm gauge so you can actually read it! I have an Omori 52 egt and matches the green WRX cluster perfectly. I think Defi makes some nice amber/red ones to match the STi. Good luck!
Guest
Posts: n/a
i was looking at the autometer carbon fiber 52mm gauge. is it easy to tap?
def. tap it upstream MORE!!
www.gsxRpaddock.com <---gsxR research, solutions, & support
www.iWSTi.com <---STi research, solutions, & support
www.TOPSPEEDsales.com <---STi premier tuning and performance
Guest
Posts: n/a
Originally Posted by subbykid
I did mine myself, gotta make sure you take it off so you dont get metal shavings in the turbo. Also DEFI is a beautiful guage for the STI, matches perfect.
Guest
Posts: n/a
no the 1/8 tap I bought from ace hardware for like $10. I tapped mine on the cylinder #3 header, I know that cylinder gets prone to running leaner than the others, so I wanna watch that first.
