apexi TT install help
Guest
Posts: n/a
i have a apex i turbo timer and i need help installing it. i have the HKS harness also. where do i plug the harness into the car at? where do i wire in the 3 wires? i need help getting this thing installed. any help will be appreciated.
There is a blue plug for the harness to go into, at least there was on my car. The 3 wires have to run to the ECU and you have to use the Pin diagram to match the wires to the ones running to the ecu. one of the wires is a speed sensor wire, the other is a RPM sensor wire and the last if im not mistaken is for the volt meter.
Guest
Posts: n/a
Maybe it was only 2 wires then, it has been a while since i did mine. I would look around online for a pin diagram of an STI.
Guest
Posts: n/a
