Subaru Tech All We'll Drive
Need Help With Blow Off Valve !!
Old Aug 5, 2005 | 07:02 AM
MonTanaT83's Avatar
Angry Need Help With Blow Off Valve !!
When i got my car ( subaru wrx 2002 ) with 34000 on it and it came with a hks BOV and it didnt work for some reason and then i saw he use to have a apexi AVC-R Boost Controler and he kept all the wiring in it and just took the sreen for it so i was thinking that might have something to do with the BOV not working because there is a hose running from it to the BOV so i got a AVCR boost control hooked it up it works perfect but my BOV is still not working im guessing it might just be broke or something .. someone help me if u know what im talking about
THANKS
Bradd
Old Aug 5, 2005 | 07:10 AM
Sean_StI's Avatar
Slow Sti
bov, has nothing to do really with the EBC....
it probably just broken
Old Aug 5, 2005 | 08:25 AM
LeroyDriver's Avatar
Five Mile Style Baby!!
i would have to agree it is probably broken but you could try and find someone with a stock WRX and install it on thiers.
Good luck!
Smile!! It could be worse!
Old Aug 7, 2005 | 06:29 AM
I'm Slow's Avatar
I'm Slow
What do you meen it's not working? Do you mean that it doesn't make a noise? Maybe it is setup to recirculate? If its on the car and it was not working properly then the car would idle like crap!
Old Aug 7, 2005 | 09:58 AM
Hostetler's Avatar
'MERICA!
Check the vacum hose off the BOV
Ban Senor Honda
Old Aug 7, 2005 | 11:48 AM
GsEclipse02's Avatar
+1
are yalls car's map or maf?
Old Aug 7, 2005 | 11:52 AM
I'm Slow's Avatar
I'm Slow
If the vacuum hose was was off or only partially on the the car woul;d idle like shit and it would be obvious there was a problem.
Old Aug 8, 2005 | 11:19 AM
BrewPuBeaver's Avatar
*Big Schpellar*
and more than likely you wouldnt be able to boost more than 7-9lbs.
when you say it is broke do you mean you cant hear it???
Old Aug 8, 2005 | 11:34 AM
I'm Slow's Avatar
I'm Slow
