Subaru Tech All We'll Drive
Sti Tmic ?
Old Jul 28, 2005 | 01:02 PM
I'm Slow's Avatar
I'm Slow
Default Sti Tmic ?
Would a STI TMIC be sufficient for a VF-22 turbo setup on a WRX 2.0 block? I am thinking that it would be good, but at the same time I beleive that it will get heat soaked wayyyyyy too quick. At the same time though....getting a fmic will cause much more lag as compared to the tmic. I am having a tough time deciding.
Old Jul 28, 2005 | 01:52 PM
SnowMann's Avatar
TR Shop Mod
I would feel comfortable running a VF22 with one.
SnowMan tuning
Old Jul 28, 2005 | 03:52 PM
BrewPuBeaver's Avatar
*Big Schpellar*
i wouldnt in FL. a vf 22 is best when used with a FMIC. the lag factor is already present with a VF22, adding a FMIC would benifit you greatly in the long run.
you will get heat soak very bad with a STI TMIC. will you be running a water sprayer, water injection, C02 fogger, or any other sort of set up?
have you already bought the VF 22? this turbo is more suited for a 2.5L engine. not saying it wont work, just not my first choice.
if you wouldlike to speak to some one that is running the VF22 and has had a STI TMIC, MRT TMIC, and now a Perrin FMIC. Joel would be a great sorce for info. info@rallitek.com or joel@rallitek.com
Dave's .02
Old Jul 28, 2005 | 08:57 PM
Alberto411's Avatar
Science McGee
I'd do a TMIC with a VF22 or any aftermarket turbo setup. As much as I like FMICs and as good as the other's points are, I like the least lag which will, in most cases, come from the TMIC. Additionally, another trade-off or running a TMIC is increased water/oil temperatures, because of the radiator blockage. Here is a linkto a guy on NASIOC who ran into increased temps and needed a supplemental oil cooler because of his APS DR725 in the Arizona heat.
If you're not set on only the VF22, Gruppe-S has a sweat deal on the VF34s w/ STi injectors and fuel pump for $1199 shipped; looks like they're trying to get rid of some stock The VF34 won't be as laggy as the VF22 obviously, however aren't rated as highly horsepower wise as the aforementioned VF22 - makes sense since the VF22 is bigger. They also have Helix TMICs for $599 which are a little bigger than the STi TMIC IIRC.
Heat soak being your main concern though, you can get a turbo heat wrap and exhaust wrap to keep that at 'bay.'
As others have said also, don't forget to factor what you feel suits your purposes in the long term though...
Hope all this nonsense helps...
-AL-
Just an easy rider on 4 and by 2...
Old Jul 31, 2005 | 03:50 PM
I'm Slow's Avatar
I'm Slow
Thats what I was thinking, considering it isn't that much bigger than the STi turbo.
Old Jul 31, 2005 | 07:28 PM
black rex's Avatar
get a fmic!!! will work way better, but dont take my word for it i just have a stock wrx.
Old Jul 31, 2005 | 08:09 PM
Apexi wrx's Avatar
The NExt Brian O' Conner
Joe dont listen to mike you are getting the topmount as a deal so take it bro sorry mike that frontmount is tooo big but i guess u like it big j/k
Vroommm psshhh
Old Aug 1, 2005 | 08:44 AM
I'm Slow's Avatar
I'm Slow
Yeah, he likes it big and black
