lowering suby
Don't half-ass it. If you're going to spend the money modifying your car, do it right else continue saving till you can. In an ideal situation, lowering the car would only knock out your camber specs but in reality since you will be unbolting the hub to get to the strut, chances are you'll be introducing some (minor) changes to toe settings. Will the car be undriveable afterwards? No, but you may experience some unnecessary tire wear (minor again) if the toe is off. And don't look at the alignment as being an expense, look at it as being a performance enhancement. You'll have the ability to set a more aggressive tune and get away from the stock settings.
let the springs set for about a week (or one day of agressive driving), and then perform the align.
even a completely oem sti could benefit from an align, after some miles....
ese
ese
www.gsxRpaddock.com <---gsxR research, solutions, & support
www.iWSTi.com <---STi research, solutions, & support
www.TOPSPEEDsales.com <---STi premier tuning and performance
Mastro did an excellent alignment on my car after I put on the suspension, which I did myself. When we did it the guy helping me had a tool you put on one of the lug studs to let you reset the camber close to what it was with the new stuff on it.
I don't recall, but I really don't think they had to do much, aside from set it up for performance (I think I have -1.5* camber in the rear and -1* front)
If i lower my wrx do i need a camber kit or is a alignment the only thing i need?
Car History
97 Civic Hx coupe--Sold
02 Wrx w/usdm Sti swap--Traded in
04 Sti --Sold
96 Civic hatch w/ ITR swap--Sold
90 Civic Wagon B16--Traded
90 4Runner v6 4x4--Sold
08 Civic Lx--Traded in
11 Sti SWP Sedan--Traded in
*11 4Runner Trail Edition 4x4 --DD
*08 FX35 -- DD
Car History
04 Sti --Sold
*08 FX35 -- DD
