Went to CFT today, came home with some pics
it was because Justin was scared that he was gonna break something, at 27 psi rolo kept it rich he say if he leans it out some and 30 psi and he does what he wanted to do with it from the begging he say it should make 600 or better
Alex I hope you take it easy on that tranny. Even though it is a v6 STi tranny, I think you may need to take it easy with 600whp! Also are you going to be spraying to spool? You might as well seeing how the motor is fully built. A little spray to spool up will give you a much stronger powerband.
550/550
word, sounds much better then. Looks like everything has been thought of so you should be good to go! I would still consider a small shot though
Originally Posted by alex03wrx
I have a V6 with RA gearset and cryo treated
Good luck with that.
Yes, it will help.
There is no way in hell the teeth on those gears will hold 600-some-odd ft/lbs of torque for long. They are far outclassed by that amount of power.
I will happily stick my foot in my mouth a year from now if alex03wrx continues to drive the car at that level and has not broken gears.
