Subaru Tech All We'll Drive
n2o on STi
Old Jun 8, 2005 | 12:33 PM
schoellnasty's Avatar
Id be interested in the same info for a regular wrx.
Old Jun 8, 2005 | 01:50 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
+1 a wrx with a 40 shot put around 80-90 to the wheels After I get my motor done it will get sprayed, dont expect me to tell you how much
Old Jun 8, 2005 | 02:36 PM
I'm Slow's Avatar
I'm Slow
I wouldn't spray unless you build the motor. After all the research I did on spraying the WRX, I decided not to because the majority of the WRX's or STi's that spray end up blowing the motor via spinning a rod or rod bearing blowing.. Being that you are still on the stock turbo, then a small shot should be ok......given that plenty of STi's are running the SR 40-50 turbos with no problems. The power increase could be compared to a larger turbo, however be careful........Spray is more addicting then boost.
Old Jun 8, 2005 | 02:40 PM
I'm Slow's Avatar
I'm Slow
Also, I would go with a wet shot over dry
Old Jun 8, 2005 | 02:58 PM
04evo2's Avatar
with the way are mass air is you could easily just bolt up a 50 dry shot and not have to do any tuning. but thats on a stock sti. you may have to lower your boost a bit.
Old Jun 8, 2005 | 03:33 PM
I'm Slow's Avatar
I'm Slow
This is probably why the majority of WRX/STi's that get sprayed blow up! It is not recommended to throw spray on any car with just the stock tune......at least get an AFC or something.
Old Jun 8, 2005 | 03:54 PM
stockcobra's Avatar
soory to intrude,but i guy i know, i believe he is marksaccord on tr he blew his wrx when he was spraying. maybe he might be able to help you on what not to do.
