Subaru Tech All We'll Drive
100 octane = slow STi???
Old May 31, 2005 | 10:09 AM
I'm Slow's Avatar
I'm Slow
Originally Posted by kickslop
Have you given the ECU a chance to add timing? Stop resetting it.
That's the only thing in the stock ECU you will seen gains from by only increasing octane, and if your timing advance was fine at your boost levels already, you're not going to see jack and will likely see a loss of power. Higher octane fuels burn slower. If you're not starting combustion earlier (through ignition advance, which you have zero control over right now), you have effectively just worsened your combustion events.
No Subaru is "tuned to" a particular octane.
+1 pretty much sums it up!
Also, I too would like to know what made you fill the entire tank and spend $74 on race gas when you do not have EM
Old May 31, 2005 | 01:09 PM
DubtecV2's Avatar
...in da hause!!!
Actually, my roommate bought the gasoline...I paid nothing
CEL is for the O2 sensor, I've been lazy and haven't gotten a fix for it yet.
You guys say 100 octane will make the car slower? It sure as hell made my father's WRX faster...
Old Jun 1, 2005 | 05:23 PM
spencerxi's Avatar
dumb
Old Jun 1, 2005 | 05:37 PM
  #17 (permalink)
Alpha's Avatar
Originally Posted by 04evo2
i know of a sunoco on dale mabry, but its like $5 a gallon.
Just for reference it's $6.00/gallon now.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Jun 1, 2005 | 08:08 PM
  #20 (permalink)
subbykid's Avatar
Got Boost?
the higher octane actually only helps if you are pushing more than normal boost, or higher compression. It really helps prevent knocking and such and burns better. But if the ecu reads different fuel or such it will pull timing alot. I was going to put some in the subby and in the bike, but neither are really needed.
