APS tapered flex uppipe.
Anybody heard good or bad things about these? I decided to install an uppipe myself to save $$$ on something i can do myself. My main question is, would the taper in the pipe make a difference, and is this pipe worth paying $100 more than other flex uppipes? Please give me facts, not opinions on APS products being overpriced. Thanks.
I have heard good things, especially for the WRX. I heard that the WRX stock up pipe will crack when you change to a bigger turbo. I don't know first hand just what I heard.
"Is it worth it" is subjective. Nobody can really answer that for you.
Is it worth it to pay $385 for one made out of Inconel?
I have not heard anything bad about the APS piece.
You really need to ask this question to a larger audience (if you haven't already).
mantra1 has one and he said his VF22 spooled quicker with the APS up pipe. Thats the only thing I've heard, hope it helps
Originally Posted by JON3KGT
I found it for $250 at rallysportdirect.com, I think i am going to go ahead and order it.
I think he's got a good deal on them and tell him Joe from Tampa sent you.
It's a nice uppipe and if you can find it for $250, then get it.
Pros:
Tapered design
Flex section with w/SS innertube (prevents exhaust gases from touching flex material)
Cast Iron to keep the heat in
Cons:
Expensive
Cast Iron design prevents from tapping an aftermarket egt gauge (no welding)
After my MRT Flex Uppipe blew out, I had to make a decision fast (no down time) and Mastro had one in stock. Works great and gained about 100 rpm in spool up (no SHIT!). Also helps having RA gears too. Good luck with the install.
Pros:
Tapered design
Cons:
Expensive
Pros:
Tapered design
Cons:
Expensive
Pros:
Tapered design
Cons:
Expensive
