Subaru Tech All We'll Drive
Did some work....
Old Mar 16, 2005 | 05:16 PM
FastRaft WRX's Avatar
Down South Supplier
ive been trying to disable my drl's forever, how the hell do you do it! lol
Originally Posted by blacksti
stop trying to be cool telling people you kicked me out of your tree house lmao dude fs is gay get over it
Originally Posted by antibling
bob you are just way too cool
Old Mar 16, 2005 | 05:58 PM
mantra1's Avatar
Shaggin' Wagon IV
Check out Scoobymods.com. They have a write up on how to disable the drls. It's just a plug that needs to be disconnected.
Old Mar 16, 2005 | 06:21 PM
stokdd's Avatar
WRXtasy
the DRL module is on the passenger side front shock tower. First, start by removing the airbox. In order to remove the lower half of the airbox, you'll need to remove two 12mm bolts down low - you will need at least a 6" extension.
Next, look at the front of the shock tower. Underneath the black bracket, there should be a silver box. It's like 1"x3" in size and says "Caution High Temp" in red.
All you need to do is unplug this module. You can remove it completely if you want, then zip-tie the connector.
Next replace the airbox and you're done!
Old Mar 16, 2005 | 06:25 PM
stokdd's Avatar
WRXtasy
Be patient, people. Phone isn't uploading pics at the moment.
I also made a custom aluminum mesh grill. Looks much better, and protects from rocks and bugs that would normally be able to go through and damage A/C condenser.
$10 I'll make you one and install it, too
Old Mar 18, 2005 | 08:48 PM
stokdd's Avatar
WRXtasy
Here are a few pics. Imma wash her tomorrow and take more.
Old Mar 19, 2005 | 04:22 AM
JonLGT's Avatar
Just for decoration
Not showing.
Old Mar 19, 2005 | 05:00 AM
  #18 (permalink)
QuickOne's Avatar
It's soooo stock?
Originally Posted by 02CavyZ24
was it easy to de-badge the trunk? ive been thinking of doing mine. are there holes behind the letters or are they just glued on?
Easy! A little dental floss or 20lb test mono and some goo-be-gone. No holes.
Old Mar 19, 2005 | 06:33 AM
  #20 (permalink)
stokdd's Avatar
WRXtasy
Try 'em now.
