Subaru Tech All We'll Drive
Injector install
Old Feb 12, 2005 | 07:25 AM
mantra1's Avatar
Shaggin' Wagon IV
Question Injector install
I have a new set of PE650's sitting on my desk. Dealer wants three hours of labor cost for the install. Anybody done this? Looking for some help.
Old Feb 12, 2005 | 07:44 AM
esemes's Avatar
TTwins are my fav
do you have the new clips??
((the 850's require their bracket and clip/plug))
Old Feb 12, 2005 | 11:05 AM
disalvoj's Avatar
Doughnut Grease
Found this on another forum last night.
Here you go...[P][BR]Depressurize the fuel system: [P]Remove the 3 plastic screws securing the passenger side carpeting against the floorboard and expose the factory ecu. [P]Pull the plastic trim panel on the right side to expose the two electrical connectors shown below [P]Unplug the green connector shown below to disable the fuel pump. [P]Start the engine and run until it stalls. [P]Crank the engine over for 5 more seconds. [P]http://www.turboxs.com/_images/Fuel_Pump_Relay.jpg[P]Drivers Side Injectors:[P]Remove "green" protective bracket from the fuel rail assembly by the 5 bolts. This is a "PITA" but be patient and pull it out towards the rear of the car. [BR]Remove 2, 12mm bolts between the injectors securing fuel rail to the heads and 1, 12mm bolt at the front of the fuel rail. [BR]Disconnect electrical connectors from fuel injectors [BR]Pull up on fuel rail and slip out injectors one at a time. Be careful not to damage the fuel injector's rubber gaskets. [BR]Install TXS Fuel Injectors in reverse of task "4." [BR]Put everything back together from "Install the Larger Fuel Injectors" in reverse order. [BR]Passenger Side Injectors:[P]Remove the coolant assembly located next to the intake manifold. [BR]Remove the various bolts securing hoses to the "green" bracket. [BR]Remove "green" protective bracket from the fuel rail assembly by the 4 bolts. This is a "PITA" but be patient. [BR]Remove 2, 12mm bolts between the injectors securing fuel rail to the heads, 1, 12mm bolt at the front of the fuel rail and 2, 12mm bolts at the top of the fuel rail. [BR]Disconnect electrical connectors from fuel injectors [BR]Pull up on fuel rail and slip out injectors one at a time. Be careful not to damage the fuel injector's rubber gaskets. [BR]Install TXS Fuel Injectors in reverse of task "6." [BR]Put everything back together from "Install the Larger Fuel Injectors" in reverse order. [BR]Double check Installation:[P]Make sure the all electrical connectors are installed to the fuel injectors. [BR]Make sure electrical connectors are installed to the Tumble Generator Valves if removed during installation. [BR]Make sure the fuel pressure regulator line is attached and secured. If installed improperly, serious engine damage can occur as fuel pressure will not increase with boost. [BR]Plug the green connector back in from "Depressurize the fuel system."
Here's the link http://forums.vividracing.com/archiv...hp/t-9483.html
V/R
-Joe
My IWSTI.com Garage
"This is how I roll!" ~Jack Black
Old Feb 13, 2005 | 06:49 AM
mantra1's Avatar
Shaggin' Wagon IV
Looks pretty time consuming, I also have to factor in the Perrin fuel rails that are already installed. Thanks for all your replies.
Old Feb 18, 2005 | 08:00 AM
KAX's Avatar
KAX
sounds like fun... ive got a set of UR680s to go in, and compared to that you have it easy. Ive got resistor boxes to install too.
Old Feb 18, 2005 | 10:21 AM
Apexi wrx's Avatar
The NExt Brian O' Conner
If u need help let me know i did my sti injector by my self
Vroommm psshhh
