Subaru Tech All We'll Drive
break in questions
Old Dec 13, 2004 | 06:11 AM
Tits McGee's Avatar
is cooler than you
Other than maybe an oil change, just get more familiar with the gas pedal.
Old Dec 13, 2004 | 06:53 AM
lstepnio's Avatar
1337 H4x0r
I wouldn't really suggest changing the oil until whatever it is that Subaru recommends. There is no reason to waste perfectly good oil. I would aim for around 5,000-6,000 miles between oil changes on our turbo Subarus when using Mobile One. I would submit every other or so sample of oil to blackstone-labs.com for oil analysis to make sure everything was happy with the engine and oil. I'm aiming for a 7,500 interval with the Acura pending oil analysis from the second oil change after switching to Mobile One.
If you like to be obsessive I would suggest the services of blackstone-labs.com.
Here are two sample report from my '02 WRX and '04 STi:
http://www.majjix.com/~lstepnio/oil_...0103-30000.pdf
http://www.majjix.com/~lstepnio/oil_...30904-7323.pdf
-luke [www.majjix.com]
Old Dec 13, 2004 | 07:05 AM
kickslop's Avatar
noodles
Hopefully not turning this into another dreaded "oil change interval" thread, but I definitely agree that people are far far far overzealous with oil changes -- to the point of wasting perfectly good oil and perfectly good money. You DO NOT need to change your oil every 3000 miles.
As far as your question goes: No.
Old Dec 13, 2004 | 07:13 AM
Tits McGee's Avatar
is cooler than you
Well on a brand new car, it doesn't hurt to change it after the first 1000 miles, after that, then yes, I agree, no need to be super overzealous about oil changes.
Old Dec 13, 2004 | 07:22 AM
lstepnio's Avatar
1337 H4x0r
Just because something doesn't hurt something it doesn't automaticly mean it's going to be a good idea. It's not helping anything and if anything it's wasting time, money and natural resources.
I'd get myself a beer and call it a day.
Old Dec 13, 2004 | 07:35 AM
Tits McGee's Avatar
is cooler than you
I never knew that leaving tiny debris and metal pieces that can show up during break-in in a brand new motor was a good thing. Silly me. But what do I know, since I had to rob a bank to buy my car.
Old Dec 13, 2004 | 09:30 AM
lstepnio's Avatar
1337 H4x0r
I hate to be argumentative but you know I can't help myself.
There is a very effective oil filter in your vehicle to catch any possible debris and metal pieces that might be dinging around. There is no doubt that there are trace elements that are going to be in the oil that are characteristic of modern engine break-in that oil filter might not catch. These particles aren't "pieces" nor are they "tiny" but they are microscopic in size.
I just pulled the factory oil out of our new TL at 7,000 miles and there wasn't a single particle or any metalic sludge on my magnet thanks to the oil filtration system.
Consider that even Subaru which is going to to encourage you to patronize your local Subaru Service Department as much as possible recommends the same interval for the first oil change as when the car has 100,000 miles. That fact in mind realize that as the engine ages your oil change interval should actually progressivly shorten over the life of the engine.
Old Dec 13, 2004 | 11:21 AM
Charles's Avatar
Senior Member
+1 for doing whatever the owner's manual tells you
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
