Subaru Tech All We'll Drive
Need a Tranny or someone to rebuild one
Old Oct 21, 2004 | 07:25 AM
chevy eater's Avatar
Default Need a Tranny or someone to rebuild one
My tranny is making noise in second gear and i either need to find one or get mine fixed,any suggestions would be greatly appreciated.
Thanks in advance,
Kevin
02 wrx 5-speed
Old Oct 21, 2004 | 10:26 AM
Thanks,I don't know what happened to it,it just started making a clicking noise that gets faster as the car goes faster
Old Oct 21, 2004 | 10:45 AM
it is not bad,bad enough I haven't drove the car in over a week.
Afraid for it to come apart and destroy everything.
It still drives perfect,just the noise
Old Oct 26, 2004 | 12:06 PM
split case yesterday,and could not find nothing wrong with the gears,will finish tearing apart today to see if diffs or something else is wrong,I thought for sure it would have been a broken tooth on second gear but it wasn't
Old Oct 26, 2004 | 08:28 PM
Epstein's Avatar
Retired
yikes! I probably would have just checked the magnetic drain plug first. Although, hind sight is 20-20. Any missing teeth should have shown up there. It might just be a bad input shaft bearing.
Old Oct 28, 2004 | 05:43 AM
no missing teeth,all bearings fine,but when you turn it by hand you can feel it.
I think the input shaft is bent,1st and 2nd gear get a lot of backlash and get tight when you turn the input shaft
