Subaru Tech All We'll Drive
EJ20 into 90's Impreza conversion on a budget.
Old Feb 29, 2004 | 07:22 PM
lstepnio's Avatar
1337 H4x0r
Default EJ20 into 90's Impreza conversion on a budget.
I'm playing around with the idea performing EJ20 conversion into an older Impreza as fun/track vehicle that I won't mind smashing around. I'm hoping to start by locating an inexpensive Impreza that is equiped with AWD and working 5MT. I'm looking to some of you guys for some suggestion on finding something usable but very cheap so my wife doesn't freak out too much. I know some of you have researched this and I'm just hoping to get some ideas.
-luke [www.majjix.com]
Old Mar 1, 2004 | 04:02 AM
Dirt Man's Avatar
Sucks to be You!
Last months Sport Compact car had an excellent article on the swap/conversion. Everything they say was easy except the wiring harness.
I'm meaner, stronger, and way more bitter than you are! So don't FUCK with me!
Old Mar 1, 2004 | 04:37 AM
M249SAW's Avatar
Firemedic / Local 4420
5-speed AWD Coupes are hard to find. Florida dealerships didnt get alot of them. So if you find one it usually from up north and has alot of body rust. Thats why I settled for my car a, 2WD AT Sedan.
IF you are doing a swap its just a little more work to convert the drivetrain.
Kyle
Old Mar 1, 2004 | 06:21 AM
lstepnio's Avatar
1337 H4x0r
I honestly was hoping to avoiding swapping the transmission, diff and axles or at least until something snaps and needs to be replaced. My understanding is that if you're going to swap the transmission you really open up a whole big and expensive can of worms with other things that are required such as the clutch, axles, diff, etc. The wiring actually seems pretty easy and well documented but just time consuming.
Zate, The reasoning as why I wanted to stick to the EJ20 is that they can be aquired for around $1,000 in working condition with <50k miles including ECU, and entire WRX wiring harness. The one I have my finger on right now just needs a turbo. Also, the USDM EJ20 ECU can easily be reflashed for supporting mods.
Kyle, how much did you end up paying for the 2WD AT Sedan?
Old Mar 1, 2004 | 06:49 AM
M249SAW's Avatar
I payed $750 for my car
Old Mar 1, 2004 | 06:59 AM
lstepnio's Avatar
1337 H4x0r
Was the vehicle in running state? Was this purchased from auction? Briefly, what have you swapped into your car? How much did the whole project end up costing labor aside?
Old Mar 1, 2004 | 07:21 AM
M249SAW's Avatar
I bought it from our used car lot. It runs liek a champ and has no mechanical problems other than the A/C doesnt work.
Thus far I have not started my drivetrain swap as I am preparing the chassis to handle all the extra power.
I have done the following:
99 RS Wheels/Nitto NT450 tires
Front Subaru 4-pot brakes w/DBA slotted rotors
Rear drum-to-disc conversion with DBA Slotted Rotors
Goodridge stainless lines
Whiteline Front and rear strut bars (In my closet at home)
Whiteline Front and rear sway bars (In my closet also due to waiting on STi rear trailing link set)
Various JDM Cosmetic stuff (Taillights, corner lenses etc)
