Subaru Tech All We'll Drive
Boost pressure in cold weather
Old Dec 7, 2003 | 02:27 PM
TampaWRX's Avatar
danse
Default Boost pressure in cold weather
I know we should expect some boost creep/increase in boost pressure due to cold weather, but I'm wondering how much everyone else is seeing? My factory manifold pressure sensor registered 20.2psi during a run last night. Timing advance looked to climb all the way to 36deg or thereabouts, assuming I am reading the data display right. No knock correction, etc was present. Anyone seeing 2+psi of extra wind on their setups? I likey, but prefer to err on the side of caution. EGTs looked solidly below 1400degF, so no big worries there.
“You will never do anything in this world without courage. It is the greatest quality of the mind next to honor.” - Aristotle (384 BC-322 BC)
Want to know what the war in Iraq is really costing America? Click here
Old Dec 7, 2003 | 02:33 PM
CrapBag's Avatar
Mouthhugsarenice
last time i drove my car in the cold i saw 28psi on i75:o i'm only suppose to run 24
Old Dec 7, 2003 | 02:35 PM
TampaWRX's Avatar
danse
Goddamn...like that thing needs anymore help!
Old Dec 7, 2003 | 03:57 PM
722ish's Avatar
ASM FTW!
my car was pulling like a train, then, it popped a cel...
95 Supra Turbo 6 speed
11 SWP STI sedan
Old Dec 7, 2003 | 07:20 PM
TampaWRX's Avatar
danse
I have now logged codes: P0301(twice), P0302 and P0303. All misfire codes, all related to the lightened flywheel currently in the car. I need to find a way to turn this damn CEL off, as it's getting annoying.
Billy, how'd you do it again?
Old Dec 8, 2003 | 05:52 AM
TampaWRX's Avatar
danse
Originally posted by Billy
Like I was telling you last night, if I turn the air off (which has been happening a bit more with this cooler weather) and drive around for a few driving cycles the light usually goes off in a day or two. It then pops back on when it feels like it, but no biggie.
Thanks bud. This misfire code is a pain the ass. I hope they find a way to turn the damn code off permanently with EcuTek.
Old Dec 8, 2003 | 09:19 PM
ImprezingYou's Avatar
Booyakasha
i was talking with one of the mechs from mastro and he said if you turn the ignition to "on" (dont start the car) and then turn it off after about 30 times the light will go away temporarily.
Old Dec 9, 2003 | 06:32 AM
lstepnio's Avatar
1337 H4x0r
I assumed they could do this already. I know the Cobb reflash can disable any specified CEL. You want to look into this as it's possible it's supported but the folks at Mastro aren't aware of it?
-luke [www.majjix.com]
Old Dec 9, 2003 | 08:37 AM
TampaWRX's Avatar
danse
Could be. There's also a way to open up the ECU to limited user changes via Delta Dash. Can you help me/us out here Kyle? If there is a way to turn off this CEL(group of CELs, actually) for good, I would very much like to do so. I would also like to turn the user options on as well.
