Turbo Question
There is a guy in tampa called CMR Turbos, he told me that he could take my td04 and make the compressor side an equivilent to a 16g... he said if I keep the boost around 16lbs i wouldn't have to upgrade the feul system. Now my question to you guys is what do you think i should do? Hes charging 600 dollars to do it. Now keep in mind i have a very small budget, and I KNOW i should just get another turbo... I COULD afford another turbo, but I cannot afford all the other stuff I need (i.e. feul, etc)
Opinions please
Opinions please
www.myspace.com/beyondthemire
Guest
Posts: n/a
I'm not sure what the results would be like doing the hybrid, so I can't comment much on that. But, I do know of a few people that have really pushed the limits of the stock fuel system and it didn't take much to do it. When I was researching boost controller info I was told by more then one reputable WRX tuner that the stock fuel system is capable of supporting ~17psi from the stock turbo. That being said, I don't know how comfortable I would be running 16psi on a turbo that could flow more cfm. Maybe someone with somemore knowledge can chime in and give their $0.02.
basically, the stock fuel rails are crap too.... cyl #3 has a reputation for one reason or another..... also, a TDO4 into a 16gk would be a skittle turbo..... i think. basically, i would at least upgrade the injectors, if not the rails/pump too!
as billy said, ive heard the same, the stock turbo maxes out the stock fuel stuff right around 17, Alan told me a few guys were in there with 18 psi, but i dont know how the ars turned out, for all i know, they might be fine, or they might be blown up....
as far as compressor changes, sometimes big compressor/too small of an exhaust housing = inefficiency.... which means, it might flow more air, creating more power, but that pig might also be heating up the air like crazy.... from what i know, a 16 can put a DSM in the 12's no bother, so... you should see similar results, i think.
although, with the stock intercooler, you have to pull some boost/timing advance possibly, seeing as that turbo might be less/more efficient... youll just have to wait and see i suppose...
95 Supra Turbo 6 speed
11 SWP STI sedan
11 SWP STI sedan
you can easily run 16psi on the stock pump, injectors, and rails. there is a "monster TD-04" for sale on either nasioc or clubwrx for 400. i would not spend more than that on any td04.
www.coastaldyno.com
Smackin down LS1s since 99', LQ4s too...
www.coastaldyno.com
For $600 you're getting close to VF22 or VF29 territory. Any of the above choices will require injector and rail upgrades.
“You will never do anything in this world without courage. It is the greatest quality of the mind next to honor.” - Aristotle (384 BC-322 BC)
Want to know what the war in Iraq is really costing America? Click here
