suspension launch tuning
Mouthhugsarenice
on
was wondering what is best for launching i have heard soft in the rear for better launches but what about the front i have no idea what works best to get that forward momentum
Soft in the rear would lift the front wound't it? If it was super stiff it would keep the front down but I don't know much about all that weight transfer stuff.
Learn how to use the feedback system! When people don't fallow through with a deal, fucking make it known! of course everyone has all positive points, no one fucking gives negatives for flakers, if you start giving negative feedbacks for flaking maybe people on tr will stop making stupid ass posts about wanting to buy shit then not showing up for the shit.
you want the front to stay down. stiff in the back would be best i think. ill let u know im doing some stuff now to see what works.
www.coastaldyno.com
Smackin down LS1s since 99', LQ4s too...
www.coastaldyno.com
Guest
Posts: n/a
Yeah, you can pretty much throw out all prior knowledge of how to set up a car when you start dealing with the WRX. My guess would go along with Sam's thinking. Stiff and maybe even a bit higher in the back to help keep the front wheels planted.
Watching the two 8 and 9 sec AWD DSM's at Moroso awhile back, they each had two different suspension setups. One had the rear high and the front kind of low, basically what Sam is going to try. The rear was soft and allowed for weight transfer but with the front low it keet the front wheels in contact with the track. The other was slammed all around and pretty stiff. Both launched great off the line.
-Jomar-
-Jomar-
I would go with the latter (slammed) approach, as your center of gravity will be as low as humany possible to the track, but then you've got to worry about camber, etc, since the wheel/tire assembly is liable to lean and compromise mechanical grip. I still think soft in the rear might be a bad approach, but I can see the logic in trying to handle the weight transfer.
In your car, I'm thinking it is going to come down to what happens in the driveline as much as how the weight transfers through the car. If one of the fronts starts spinning due to the open diff, your launch is over with. It will be interesting to see how the center and rear diffs handle the launches, as the tires might be overwhelmed. It's really hard to say.
My thinking would be, do a couple of baseline launches with the setup as you drive it everyday, paying more attention to how the car feels when the clutch comes out than anything else. From there, start making small changes until you feel like you are going in the right or wrong direction and change your approach accordingly. It won't be fun, but it's probably the only way you're going to dial in a suspension setup that works. Knowing when to say when on changes is probably the hardest part, as too many changes will put you in the wilderness. Wish some of my road racing friends were into drag racing, as they have taught me quite a bit about setting up a car for twisty tracks, but I know shit about handling big power in a straight line.
p.s. Take notes of all your changes and their effects. It sounds silly, but that's how everyone in the big leagues does it, right down to temps, tires pressures, atmospherics, etc. The more data you acquire, the better!
“You will never do anything in this world without courage. It is the greatest quality of the mind next to honor.” - Aristotle (384 BC-322 BC)
Want to know what the war in Iraq is really costing America? Click here
